OC-3 generator,Need hook up help
Glen
02-19-2004 07:42:11
OK , got the 6 volt generator converted to 12 volt.Need a step by step on how to correctly polarize, hook it up, and is it better to go positive or negative ground?The regulator is a 3 pole Bat, arm, F,(says on the regulator 12v N/P). The battery I'm using is a regular 12 volt Walmart brand.This is how I have it hooked.Regulator Bat terminal to battery(pos) side of foot starter pedal,arm terminal of regulator to A of the generator, Field terminal of the regulator to field of the generator. Negative of battery is grounded.Does this need to go another way??? and what is a simple method of testing to see if system is actually charging.Thanks to the guys in the last message, and many many thanks to all that reply to this question. Glen
Kent of SW MO
02-20-2004 05:10:51
 Re: OC-3 generator,Need hook up help in reply to Glen, 02-19-2004 07:42:11
Why are you using a generator? Alternators much better.
Larry from MD
02-19-2004 08:55:26
All of the old delco systems were positive ground and thats the way i remember the instructions.To polorise touch a wire between the A and B posts.The old negitive systems(cat,ford)used differant posts to polorise.Other than the battery wires you have it correct.
