Hydraulic Filter
VADAVE
02-18-2004 04:14:59
Appears Craig A Tull isn't around. He had posted in about 2000 about swaping the 1855/1955 hydraulic filter canister for a spin-on from Surplus Center. Does anyone else know about this?
Who made the adaptor?
What filter--From NAPA?
IanC
02-19-2004 03:59:46
 Re: Hydraulic Filter in reply to VADAVE, 02-18-2004 04:14:59
OEM filter and head were made by Gressen. Your local Gressen distributor should be able to fix you up with a filter head for a spin on filter that will bolt right on where the old on did. If you don't have one local, the one I've used is Am-dynic Fluid Power in metro Detroit.
B A Star
02-19-2004 20:08:47
 Re: Re: Hydraulic Filter in reply to IanC, 02-19-2004 03:59:46
Using another manufacturer's filter is OK, however, make sure that you use a filter element that is rated at 10 micron, not larger.
Wrenchbender
02-18-2004 05:40:46
VA Dave, Search the archives it's still on there. I just saw the post a couple days ago. I'm thinking of revamping the filter and hyd lines on the 1955 that I'm rebuilding. I'd like to get rid of the cannister and compression fit lines. WB.
Larry from MD
02-18-2004 05:17:01
He had to change the entire filter base,canister and everything.You then mount a differant filter that uses a spin on.You have to make the hoses fit yourself.
