cockshutt wiring diagram
Dave M
02-17-2004 19:21:49
Does anyone have a wiring diagram for a 40 Cockshutt?? I am restoring one and the wiring is mostly missing.
P Heisey-Harleysville,PA
02-18-2004 19:40:37
 Re: cockshutt wiring diagram in reply to Dave M, 02-17-2004 19:21:49
Dave M,
THANKS jflem for recommending my Cockshutt parts supply service.
I can mail you a copy of the wiring diagram after you email me your slow mail address.Cockshutt 40 gas tractors went from a cut-out style to a full voltage regulator voltage at tractor serial number 6785.
Jim and Sue at: www.wiringharnesses.com in Alden, New York (near Buffalo) can supply you with the real thing.
Phil Heisey 215-256-8651 eve. FAX 215-256-1203
Dave M
02-19-2004 16:32:02
 Re: Re: cockshutt wiring diagram in reply to P Heisey-Harleysville,PA, 02-18-2004 19:40:37
I will call you today. Thanks.
Just in case I can not get you
Dave Morlock
3341 Springfield Road
Wadesville, In 47638
I just bought some seals and bushing from you. Parts were outstanding.
P Heisey-Harleysville, PA
02-19-2004 19:19:39
 Re: Re: Re: cockshutt wiring diagram in reply to Dave M, 02-19-2004 16:32:02
Hi Dave,
Thanks for your very favorable comments regarding the parts shipment.
I tried to call you this eve. but your line was busy.
The wiring harness on your Cockshutt 40 has one wire to the full voltage regulator(from the amp gauge). The earlier 40 with the cut-out style voltage regulator uses a second wire from the generator post to the special three step light switch. It appears this is the only difference.
I will mail you both the wiring diagrams.
Dave M
02-19-2004 16:47:51
My serial number is 9907, a 1952 model. Will this make a difference in the wiring harness??
Unimog
02-18-2004 06:19:04
If you get the owners manual, there should be a
diagram of the wiring in it. Keith McClure at
www.valkyie.net/~ckp has many reprint manuals at
a reasonable price. Also the Floyd County Museum
has reprints and some original manuals. Their
number is 641-228-1099. A new harness can be made
by this outfit, wiringharnesses.com for your
tractor.
jflem
02-18-2004 05:47:28
This is the man to contact with all your cockshutt needs:
Phil Heisey
641 Store Road
Harleysville, PA 19438-2717
Phone 215-256-8651
FAX 215-256-1203
