88 Hubs
Green 88
02-16-2004 04:51:08
Will a set of oliver 60 front hubs work on an Oliver 88?
Marty
02-20-2004 22:03:34
 Re: 88 Hubs in reply to Green 88, 02-16-2004 04:51:08
Are you looking for a set of light front hubs? If so, I have a set of the 6 bolt light front hubs.
Kent of SW MO
02-17-2004 07:48:08
I do not think so though I have never worked on a 60. When we were Hot Rodding an 88, We mounted
double hubs on the axles. The 88 rear end we used
had longer axle than normal.The way we ran the double hubs was mount one hub, set the wheel on and then slide the other hub on. We were using a Early Chrysler Hemi .625 stroker with Hilbron injection.
