Adding a valve to a Super 77
Randy Zimmerman
02-12-2004 11:54:00
We are adding a loader valve to an Oliver Super 77. Which plug on the hydraulic housing do I remove to get pressure oil?
Gary
02-15-2004 15:31:44
 Re: Adding a valve to a Super 77 in reply to Randy Zimmerman, 02-12-2004 11:54:00
You need to remove a 1/2 pipe plug on the left front lower corner of the housing. Then screw a 3/8 pipe plug back in deeper down in the hole and hook your pressure lin to where the original 1/2 plug was. Then run your return back in a plug by the oil filter on the right hand side of the housing.
ajax implement
02-13-2004 13:29:34
This will not make sense to you at all but, are you going to be also using the tractors hydraulic system while the loader is on the tractor/ I would guess the loader valve is a double spool open center valve. Was the loader on a different tractor before this (in other words it is a used loader) if so what tractor/ How often and how long do you intend to use the loader/
Randy Zimmerman
02-14-2004 11:37:09
 Re: Re: Adding a valve to a Super 77 in reply to ajax implement, 02-13-2004 13:29:34
The loader was on this tractor, however, it ran off of a pto powerered pump. We are going to use both of the tractors hydraulic outlets and are looking for the plug to remove to find pressure oil. Yes, it is a double spool open center valve. I would appreciate your help.
oleblu
02-14-2004 13:18:01
 Re: Re: Re: Adding a valve to a Super 77 in reply to Randy Zimmerman, 02-14-2004 11:37:09
Randy, on the left side of the hyd unit is a large plug, remove it. On the right side of the unit is a 3/8" plug, remove it and install it inside where the large plug was. The small plug closes a passage to change the flow of the oil. If I remember right, the small hole on the right side is pressure, and the large hole is return, if not I've got it backwards. Jim Thurnau
Randy Zimmerman
02-14-2004 19:10:24
 Re: Re: Re: Re: Adding a valve to a Super 77 in reply to oleblu, 02-14-2004 13:18:01
Thanks a lot , I appreciate your help. That's the way I'll proceed.
