550 oliver tractor pto use question
george from uls
02-10-2004 19:11:03
1959 550 tractor, other than the three point hitch, can you run some thing ie. log splitter,power angle snow blade, both at the same time or one at a time?
Kenny
02-11-2004 15:40:49
 Re: 550 oliver tractor pto use question in reply to george from ulster,pa, 02-10-2004 19:11:03
Yes you can run other Hydraulic equipment if you have the remote valve on the right side of seat.
RockinB
02-10-2004 19:27:01
Do you mean a second hydraulic operated piece of equipment.If so,you need an auxillary hydraulic valve.The PTO is independent,therefor it could run an additional hydraulic pump.
