3 point on oliver 1650
william disher
02-09-2004 08:45:29
i have an oliver 1650, when under load the 3 point jerks up and down in a hic-cupping fashion oil used is a trans-draulic type that is supposed to be compatible to the oliver type-55, it this o.k.? or would a heavier oil help, the system works fine except for the jerking motion.
J. Schwiebert
02-09-2004 18:39:43
 Re: 3 point on oliver 1650 in reply to william disher, 02-09-2004 08:45:29
Describe the load. Are you in maximum or minimum or in the middle on your draft control setting? Does your three point settle with the engine shut off?
