Alternator Wiring - Oliver 77
Ross Boots
02-08-2004 17:16:24
How do I wire up a 12 volt alternator to an Oliver 77, the alternator has 3 wire hookup, 1 threaded post, and 2 spade bit connectors on the back. How or what do I hook these 3 wires up to, to make the tractor's charging system work?
Brad A
02-09-2004 09:02:54
 Re: Alternator Wiring - Oliver 77 in reply to Ross Boots, 02-08-2004 17:16:24
Try searching the archives for a 12v conversion.Someone put up a "how to" complete with schematic(sp?}. It was for a Farmall but works great on Olivers too. I've done 4 or 5 of them. Hope this helps!
jake
02-09-2004 17:13:47
 Re: Re: Alternator Wiring - Oliver 77 in reply to Brad A, 02-09-2004 09:02:54
Try this site wiring an alternator is simple and applies to all. Its for Fords but applies to all.
old
02-08-2004 17:50:51
Hard to answer with out knowing what alternator you have Delco? internal reg or external reg etc. If it where me I'd put a delco 1 wire on it and make it simple
