super 55 pto lever
CK
02-07-2004 21:54:14
I have been looking at a Super 55 to purchase. I do not know one thing about an Oliver tractor. The problem is the pto,you have to hold the pto lever back for the pto to stay in gear as long as you hold the lever back the pto will turn just fine even under a load. What is wrong with the pto and is it an expensive fix. Thanks for any info. Im not wanting to put alot of money into this tractor. I'm a Ford guy wanting to broading my horizons, but I dont want it to cost me alot of money.
Kruse
02-08-2004 09:49:47
 Re: super 55 pto lever in reply to CK, 02-07-2004 21:54:14
While these are good tractors, don't buy one if
you think fixing one of these is as cheap as
fixing your Ford tractors.
I'll be honest about this even though I have
Oliver green running through my blood.
Don't believe me? Call your AGCO dealer and ask
the price on a front wheel seal to a Super 55.
It is now at $38. I thought the dealer HAD to be
making a mistake about the price, but a second
call to another dealer verified that it. If you do buy this tractor, buy all your aftermarket parts from someplace other than your
dealer. Sorry to say that, but $38 is too much
for a single wheel seal. My $.02 worth.
super55llie
02-08-2004 06:06:09
The clutchs are out of adjustment. The lever should snap in when engauged with about 35 lbs. of pull. It is an easy adjustmet if the clutches are slightly worn. 10-15 min job with a flat tip screwdriver. anything more than that means means spliting the tractor to get to the clutchs. Personally I've split a couple of them. The throwout bearing assembly, while still available at Agco, is very expensive. I would have the seller adjust it. If they can't, and it is otherwise in REALLY GOOD shape, knock 500-700 off the price. Otherwise I would walk.
ShepFL
02-09-2004 07:27:50
 Re: Re: super 55 pto lever in reply to super55llie, 02-08-2004 06:06:09
Ditto to the above comments. Also see link below for some insight to Oliver utility rigs. Super 55 is the older brother of the 550.
Super 55
02-09-2004 11:26:56
 Re: Re: Re: super 55 pto lever in reply to ShepFL, 02-09-2004 07:27:50
Shep,I like the brush bar on that 550. Did you make that?
ShepFL - nope
02-09-2004 13:27:12
 Re: Re: Re: Re: super 55 pto lever in reply to Super 55, 02-09-2004 11:26:56
third party image
That fine looking 550 is Stephen Foster Wall's of NC. I borrowed his pic as it looked better than my rust bucket. I am planning on making something similar if I can ever get a wagon frame. Right now I run without a front bumper on any rig. I have just gotten used to knowing where the front end is.
How is that Super 55 coming along? I am hoping to drag my 550 down to the 2006 Winter program. You saving your pennies? Hoping spring comes soon for you up in the Nawth country!!
Super 55
02-09-2004 21:24:50
 Re: Re: Re: Re: Re: super 55 pto lever in reply to ShepFL - nope, 02-09-2004 13:27:12
Well, I have made the Super 55 a lifelong restoration. I really have no time during the school year, but I am determined to get a shop built for a 365 day work space. I have some parts down in Washington for what I'm doing now, but my darn passport is in PA getting renewed and I can't cross the border without it.
By the way, I almost felt like cutting the grass last weekend it was pretty darn nice out.
ajax implement
02-08-2004 05:54:03
The PTO clutch is an over center multiple disk dry clutch. Does handle "snap" over center? Depending on the age of the Super 55 as the very early ones had a short PTO handle and the later ones had the longer handle this will determine howm much effort is required to snap the handle over center. You may be able to solve the problem by adjusting the clutch which is done through an access door from underneath or you may need to rebuild the clutch.
