broken steering
rusty
02-07-2004 15:01:29
while backing up, using a box blade, i did not see a stump that my frount end cought on, heard a loud CRACK. i dont know what part broke in the steering,but now my right wheel turns to far. think its in the steering box? the spindle seems ok. would be thankful for any info or just your 2cents worth. i am going back to the archives to look again. thanks guys ps it is manual steering
rusty
02-10-2004 19:20:13
 Re: broken steering in reply to rusty, 02-07-2004 15:01:29
i took your advice and did as J.Schwiebert said and you were right on target. my steering did jumped a spline. i adjuster the steering box and tye rods and ran the tractor all day with no problem. i thank you for all of your help. rusty
J.Schwiebert
02-07-2004 16:16:15
Start with simple stuff. Jack the front end up turn the steering wheel and turn it all the way to the left. Get off and see if the arm comming out of the steering gear is making contact with the stop. Then turn it all the way to the right and see if it contacts the stop. We never sold one with manual steering but the arm is splined to the shaft comming out of the gearbox. I do not remember if that is a fine spline, if it is perhaps it jumped a spline. Any how once you have tried that find the center position between the extreems on the steering wheel , Then see if the front wheels are pointing straight ahead. Confused/
rusty
02-07-2004 15:47:12
its on a oli 1550 with a wide frount end da?
old
02-07-2004 15:41:38
Whats it on????
