770 PTO
Michael Gravenm
04-20-1998 10:16:08
I have a 1958 770 diesel and noticed that the PTO will only run while I hold the lever forward. As soon as I release the handle, the shaft stops turning. Am I doing something wrong. or do I have some repairs to do to get the PTO to operate properly? Also, does anyone know where I can pick a tachometer cable for the tractor?
Thanks for your input.
-Mike
Larry h
04-20-1998 17:45:57
 Re: 770 PTO in reply to Michael Gravenmier, 04-20-1998 10:16:08
it sounds as if your pto is not locking in place this could be the lock outside is out of adjustment or the lock ring inside is broke as far as the tach cable if your housing is ok take it to a heavy truck parts outlet and have them make you the inside cable only this will save you a bunch
: I have a 1958 770 diesel and noticed that the PTO will only run while I hold the lever forward. As soon as I release the handle, the shaft stops turning. Am I doing something wrong. or do I have some repairs to do to get the PTO to operate properly? Also, does anyone know where I can pick a tachometer cable for the tractor?
: Thanks for your input.
: : -Mike
