I NEED HELP
Scooby
02-02-2004 16:46:26
I have a 1961 550, that I have inherited from my grandfather... The tractor is in good shape except for one thing, I need the throttle linkage that runs from the shaft that is connected to the rod under the steering wheel, to the throttle "plate"?? (wheer there is a spring tension disk thing)...Any Idea where I might get one , new or used don't matter, or at least a picture so I can try to make one...-Thanks a buch..-scoob
RockinB
02-03-2004 09:39:46
 Re: I NEED HELP in reply to Scooby, 02-02-2004 16:46:26
I got a new one for a 550 diesel from Maibach Tractor in Ohio.Email me for their number.
tinmank
02-02-2004 20:29:29
Try chatstractors.com. They might know where to get parts.
jeff
02-02-2004 19:32:10
Hi, I've seen the whole setup on ebay for sale .
Or try the tractor bone yards. It needs to setup
right or the governor will not work correctly.
That doesn't mean you can't make it yourself though. Jeff
ron hoffman
02-02-2004 19:08:20
Good luck. I had the same problem. I found some ball joints in a book used for lawnmower steering and reworked mine. Dont guess this is much help.
ron hoffman
02-02-2004 19:02:46
Good Luck. I had to redo mine, the ball joints went bad. I found some ball joints in a book for lawn mower parts and made them work. Dont guess this is much help.
