will motor out of 1955 fit in 88
hammer
02-02-2004 13:34:45
looking to put a 1955 motor in an 88 how much work is it
E J
02-02-2004 18:53:54
 Re: will motor out of 1955 fit in 88 in reply to hammer, 02-02-2004 13:34:45
I had a 1850 gas in a 77 at one time needed a motor in my 1750 and took it out .Those engines will bolt right in the frames of the older 77,88s have to use a short nose water pump like a 1650 and raise the rad.up a little bit .I think the 88 flywheel and motor plate bolts right on too if I remember right been a while.Shorten the hollow clutch shaft too the 310 is a longer motor even made the pto shaft work too.
Dsl
02-02-2004 15:04:12
Yep, I know of an 88 with a 1950T engine in it. The turbo sticks out of the hood, but there's a 310 under it.
