880 gas input shaft
galenv
02-01-2004 07:00:55
Need some help guys. A friend asked me about the clutch input shaft on their 880 and I know nothing about the transmissions on Olivers. Their input shaft has worn 1/2 the splines off and needs replacing, can buy 1 for the 1650 but is to long. I think he told me 3/8 ot 1/2 inch to long. Will this interchange or does he need to find 1 for the 880 specifically or rebuild his
B A Star
02-01-2004 22:09:31
 Re: 880 gas input shaft in reply to galenv, 02-01-2004 07:00:55
Ej is correct in that there are two transmissions used in the 880 tractors. Early had a spur gear type, though S/N 73 638 and 73 639 & later production had Helical constant mesh type. Early helical type did not have a lubrication system, late had a built in lube system. Early Helical transmission, had a field lube package made available. You can identify the field lube package by a pump located on the front of the transmssion housing, it is driven by the countershaft. The bottom line is that there is about 6 different input shafts for the 880. The parts book identifies them by the length.
E J
02-01-2004 14:52:50
Depending on type of transmission spur or helical Agco can get a after market shaft mine was helical had to go through Brad Maibach 330-939-0124
