what is a 1750 cockshutt?
DAN
01-30-2004 16:18:52
I AM LOOKING AT BUYING A 1750 COCKSHUTT
I KNOW VERY LITTLE ABOUT THIS TRACTOR HOW MANY HORSE POWER?
IS THIS A GOOD SOLID CHOICE FOR A TRACTOR?
IS THER A 3 POINT HITCH AVAILABLE FOR THIS? THANK YOU FOR YOUR TIME
North of Fargo
02-01-2004 13:14:45
 Re: what is a 1750 cockshutt? in reply to DAN, 01-30-2004 16:18:52
Good tractor, gas or diesel? Careful about the 3 point business though, it was an option. Our 1650 does not have it and it would be a fair bit of work to put it in as it has the external valve system for the remotes. If it has the hydra-lectric or internal valve system for remotes it will be less work/parts to change. Get a hold of a reputable tractor wrecker and get a price on parts needed to add 3pt. before you buy.
Don-WI
01-31-2004 18:41:23
The 1750, like stated, is a 1750 Oliver, painted Cockshutt red. They have either a 310 Waukeshaw Deisel or a 283 Gas Waukeshaw. They are a pretty good tractor, the gas rarely have problems, and the 310's only had problems when turboed w/out oil coolers in the 1855's. The 1755 is about 88 hp on a good engine, so the 1750 should be about 80. They have a Cat. II 3 pt hitch, but you need the right balls to go in the lower arms. They will either come with the tractor or you need to go to an AGCO/ White dealer for them. It is a very solid tractor to work with, plenty of weight to go with the HP. and they can PULL. I have pulled my 285 massey w/ rear tires locked up on a gravel driveway once w/ my 1755, which is almost the same thing as a 1750. Good luck
Donovan from Wisconsin
Jeff
01-30-2004 20:01:47
A 3 point should be available as they did come with one. A 1750 Cockshutt is the same thing as a 1750 Oliver, I think they are rated around 75-80 Hp but am not real sure. Most people on here that have them seem to like them so I guess they are pretty good
Zoltan
01-30-2004 21:14:40
 Re: Re: what is a 1750 cockshutt? in reply to Jeff, 01-30-2004 20:01:47
Hello Dan
Carefully research the particular engine of the tractor you are considering, as to manufacturer. Some are better than others, Perkins diesels are the best in my opinion. PLEASE NOTE!! I am not familiar with this tractor (88 standard yes), perhaps the 1700 series had different engine options, but I do know some of the 1800 and 1900 series were available with Perkins diesels. The other diesel engines (Waukesha?) had durability problems under heavy load and would blow with suprisingly low hours. They were weakly built (modified gas similar to 5.7 oldsmobile diesel???). I hope someone corrects me if I am talking poop.
Best wishes
Zoltan
