310 Wakeshau
Swamp Yankee
01-30-2004 14:27:07
I am getting Blue smoke unless I'M under load. I know the most common problem associated w/this would be a bad ring (s). Just looking for others input ???
J. Schwiebert.
01-30-2004 17:51:39
 Re: 310 Wakeshau in reply to Swamp Yankee, 01-30-2004 14:27:07
Since you say the problem goes away when you have the engine warm or are working it, I would suspect incomplete combustion, In other words not enough heat is generated to burn all the fuel. How is your thermostat? If you are in a cold climate, shutters may help. Remember a diesel is a heat engine, cold weather and light loads are stealing heat resulting in incomplete combustion.
Wade
02-03-2004 12:36:38
 Re: Re: 310 Wakeshau in reply to J. Schwiebert., 01-30-2004 17:51:39
My 310 diesel 1755 Cockshutt does the same thing. Warm or cold (bust mostly cold), I get some blue smoke at idle, but none with higher RPM or when working. Any thoughts appreciated as to why this is occurring. Thanks.
Luther
01-30-2004 17:23:00
Check your turbo seals (if it has one) by pulling off your air intake hose and look for oil on the inside. Just a thought. Good luck.
swamp yankee
01-31-2004 08:58:29
 Re: Re: 310 Wakeshau in reply to Luther, 01-30-2004 17:23:00
thanks for the replies. I'm up in Maine and it has been quite cold. Any further thoughts don't hesitate to call back.
gaetan
02-01-2004 10:48:33
 Re: Re: Re: 310 Wakeshau in reply to swamp yankee, 01-31-2004 08:58:29
swamp yankee where do you live in maine I live by fort kent maine maybe we could exchange
some parts sometime tel 506 992 2939 gaetan soucy
swamp yankee
02-01-2004 17:26:47
 Re: Re: Re: Re: 310 Wakeshau in reply to gaetan, 02-01-2004 10:48:33
I'm just outside Portland near New Hampshire. E-Mail [email protected]
