runs rough
Curt
01-29-2004 04:11:49
I have a 1800B oliver that runs rough after I had the mechanic out to replace the carb. He has been out 3 times and it still misses when cold or under a load. Any idea's what this could be?
Just wondering if it is an ajustment that just isn't right.
Thanks
ollie88
01-30-2004 13:34:38
 Re: runs rough in reply to Curt, 01-29-2004 04:11:49
Spray some starting fluid around to see if you got an air leak some where- I have had that happen before gasket between carb and intake was split. Good Luck
J. Schwiebert.
01-29-2004 15:44:51
I agree with both of those two. Not enough information. Have you checked the condition of the engine by the use of a vacuum gauge, taken a compression test, etc. I do not know where you are but here in the midwest a bottle of rubbing alcohol in the fuel tank might get rid of some condensation that may have formed What was the matter with the old carburetor?
RAB
01-29-2004 13:23:34
As a matter of completeness, why was the carb replaced in the first place? Was it an identical replacement( choke tube and jets etc)? Was it a new carb or scond hand? Did it run rough before?Old is guessing without enough information, but I agree with him that it could be other things. The best I could say at present is 'change the mechanic', which may not be fair on him!
Regards,RAB
old
01-29-2004 19:44:19
 Re: Re: runs rough in reply to RAB, 01-29-2004 13:23:34
Yep I was guessing going on that the carb was new or a good rebuild, and ya not really enough info
old
01-29-2004 09:27:49
Hows the plug on it and for that matter the points and rotor , cap any of them could also be the problem. Even the plug wire could cause that problem
Curt
01-30-2004 13:23:30
 Re: Re: runs rough in reply to old, 01-29-2004 09:27:49
Well I am not a mechanic.
The carb was old and told wore out. We replaced it with a new one, also replaced the plugs dist. cap, gas and gas line. He also had me install an in line gas filter. It was running a little rough when under load but not this bad. I believe it's time to change mechanics.
Thanks
