1950 injector
Aug
01-28-2004 15:48:04
I have a 1950 with S55 injectors. What is the difference between S injectors and N injectors?
Andrew
01-28-2004 17:26:12
 Re: 1950 injector in reply to Aug, 01-28-2004 15:48:04
N stands for needle valve basicly the same but different spray pattern.. i do not know what the "S" stands for but N's run cleaner and have more power becuase they inject the fuel at higher pressure so if you had N55 you would have a little more power then the S injectors
