Serial number break for 2-105 ???
JW
01-27-2004 15:12:32
Is there a serial number break or a way to tell if a 2-105 has the later engine with the oilers for the pistons?? Has a cab with metal top, silver stripe.
J. Schwiebert.
01-27-2004 17:02:49
 Re: Serial number break for 2-105 ??? in reply to JW, 01-27-2004 15:12:32
If you mean the dot four engines, dot 4 engines do not have the two covers over the pushrods. Also get the 354 U number off the engine.
B A Star
01-27-2004 19:19:36
 Re: Re: Serial number break for 2-105 ??? in reply to J. Schwiebert., 01-27-2004 17:02:49
Dot 4 engine started at S/N 297 447
E J
01-28-2004 12:40:10
 Re: Re: Re: Serial number break for 2-105 ??? in reply to B A Star, 01-27-2004 19:19:36
Is their a difference on 354 perkins diesel heads in these S/N breaks?Also what we have done is put a massey 750 combine engine 354t in the 105 white but the head is trash so can we put the orginal 105 head on the combine engine?thanks ej
J. Schwiebert.
01-28-2004 16:26:12
 Re: Re: Re: Re: Serial number break for 2-105 ??? in reply to E J, 01-28-2004 12:40:10
Just wondering, Did your 105 have the dot one or the dot four engine? Also do you know what Perkins build numbers are? Yes, there are some differences in Perkins 354 heads. Some even have tubes for the fuel injectors. I had a set of 354 manuals right from Perkins, but some have disappeared. Send me a U2U on the Hart Parr form I would like to ask you some questions. Perkins is or was depending on how you look at it like Cummins. A Cummins 855 cubic inch engine can have from 230 to 400 plus horsepower so are all 855's alike, no. Just like 354 Perkins. They were in busines to sell engines, so their can be a lot of differences in a 354 engine. If you ever get to see that 580 Cockshutt, that engine is one of the first 100 354 engines built.
