Largest Piston Sleeve For 88 Block
RW
01-26-2004 18:42:05
What is the largest piston and sleeves i can get to put in my 88 and still use my stock rods?
dan
01-27-2004 17:49:02
 Re: Largest Piston Sleeve For 88 Block in reply to RW, 01-26-2004 18:42:05
can safely bore stock sleeve to 4".
mike B
01-27-2004 09:50:22
If you are staying with the stock stroke the bore size won't change the rod lenght. Know of some 88 out to 4 3/8"
E Je
01-26-2004 19:28:57
I saw someone had 37/8 for sale sleeves&pistons for 88,s88.880new.This would make a 282 cid.
Cody
01-28-2004 06:50:33
 Re: Re: Largest Piston Sleeve For 88 Block in reply to E Je, 01-26-2004 19:28:57
My 88 is 4.420 bore. Just enough left to seal the head gasket!!
Jason
01-28-2004 07:06:29
 Re: Re: Re: Largest Piston Sleeve For 88 Block in reply to Cody, 01-28-2004 06:50:33
Cody, if you don't mind me asking are these custom pistons or out of some other engine? I guess this would be with hard block?
