Oliver 550 D Rear Wheels?
Michael
01-26-2004 02:30:18
I have an Oliver 550 Diesel (Industrial) Tractor in need of rear wheels. Can anyone help locate some? It's a great tractor and I do no want to loose it.
kent
01-28-2004 07:07:51
 Re: Oliver 550 D Rear Wheels? in reply to Michael, 01-26-2004 02:30:18
i have a pair of good used 28" X 11 wheels off a super 55 for sale --if you haven't located any, give me a call at 903-729-8349 after 6:00 pm cst
Phil -- MO
01-27-2004 08:11:33
I have a gas 550 that I converted to 28" tires when I needed new wheels. They are a whole lot cheaper than 26" tires. Phil
bastar
01-26-2004 11:03:20
I assume that the rims are rusted out from fluid. A good welding shop can cut the welds between the dish and rim and replace the rim. I have a friend that just replaced the rims on his 550 that are Power Adjust. He cut out the rails in his farm shop and welded them into the new rims after some careful alignment.
ajax implement
01-26-2004 09:46:40
If you are in the midwest, consider looking for an older 25 or 30 year old junk combine. On a lot of them those wheels will bolt right on your 550 and most of the tires and rims are in good condition. It has been done before.
Michael
01-26-2004 17:37:58
 Re: Re: Oliver 550 D Rear Wheels? in reply to ajax implement, 01-26-2004 09:46:40
I will give this a shot. I have heard of it before, but your response has made me believe.
Thanks
ShepFL
01-26-2004 09:25:20
My assumption is that the Industrial uses same wheels and tires as AG tractors. That said, new rims should not be a problem they run about $200 each. They come in 10, 11, and 12-inch widths in the 26 or 28-inch diameter. For Power Adjust the 550 takes the same 6-loop rim all of the Fords use. The rims can interchange with Massey, Ford, and Case - 8 holes on 8". Make sure to watch the center hole diameter!!
The rear tires can be 26 or 28 inches with 26 being the most common. On mine I have 13.6x28 mounted and the fronts are normally 6.00x16 but on mine I have 6.50x16.
Consider posting a want ad on this site if new wheels are not a consideration.
Michael
01-26-2004 17:35:39
 Re: Re: Oliver 550 D Rear Wheels? in reply to ShepFL, 01-26-2004 09:25:20
The Industrials are different, in that the wheels and rims are one part. I would love to find new but used will do. The want ad idea is starting to look very attractive. Thanks for the help.
jake
01-26-2004 20:08:12
 Re: Re: Re: Oliver 550 D Rear Wheels? in reply to Michael, 01-26-2004 17:35:39
Count the lug nuts again Oliver has 9, Ford has 8.
ShepFL
01-27-2004 10:40:29
 Re: Re: Re: Re: Oliver 550 D Rear Wheels? in reply to jake, 01-26-2004 20:08:12
third party image
Jake -
Don't quite get your response. Mine only has eight. Same as this pic of a nice 550 AG. Am I missing something? Are industrials 9 lug?
old
01-26-2004 07:33:32
Have you tried value bilt you can get to there web site by dropping the e and add .com
Michael
01-26-2004 17:29:26
 Re: Re: Oliver 550 D Rear Wheels? in reply to old, 01-26-2004 07:33:32
I tried it and it appears to be a helpful web page, but no wheels.
Thanks
old
01-26-2004 18:21:19
 Re: Re: Re: Oliver 550 D Rear Wheels? in reply to Michael , 01-26-2004 17:29:26
You still might try calling them, they have a lot of used parts on hand also and who knows they might have the wheels you need
