slight knock in Oliver 1600 motor
nobe
01-25-2004 15:37:12
I started the 1600 yesterday for the first time in a couple weeks. Noticed a slight knock in the motor. Could hear it on the manifold side, but not much on the other side.
Any ideas as to the probable or possible causes?
Serious or not? Need immediate action or run awhile to see if it clears up?
Thanks for any experience and advice on this, Nobe
old
01-25-2004 17:56:58
 Re: slight knock in Oliver 1600 motor in reply to nobe, 01-25-2004 15:37:12
What was the temp when you started it, did it go away as it warmed up, how was your oil preassure. If it didn't go away I'd drop the pan and see what might be loose before you put it out the side of the block, and if the oil preassure was low I wouldn't run it till I knew why.
nobe
01-25-2004 18:34:32
 Re: Re: slight knock in Oliver 1600 motor in reply to old, 01-25-2004 17:56:58
It was about 30^F. I let it run about 5 min. It didn't get very warm. It only has an idiot gage for oil pressure. That works, and it was off.
Will have to get an oil pressure gauge and check the pressure. I did rev it some and had no increase in the knock. Might call the noise a heavy peck.
I'll let it run longer and warm up after I check the pressure. Will be a few days to get that done. I have a couple of other projects before I can get a gauge. Thanks for the response. Nobe
old
01-25-2004 19:32:25
 Re: Re: Re: slight knock in Oliver 1600 motor in reply to nobe, 01-25-2004 18:34:32
Also what weight oil do you use in it ifs its say a 30 wieght and cold like that it can take a few to get it up to the parts
nobe
01-26-2004 06:42:48
 Re: Re: Re: Re: slight knock in Oliver 1600 motor in reply to old, 01-25-2004 19:32:25
The motor does have 30 weight oil in it. I usually use 10W30 for winter. Didn't change it this winter. Will do that before starting again. It is full. I always check before starting. The noise didn't sound to me like valve train. My first "guess" would be piston pin. The noise isn't very loud. I don't understand why the noise can be clearly heard on the manifold side of the engine but not on the other side. Must mean something, but I don't know what.
Thanks, Nobe
ajax implement
01-26-2004 07:00:56
 Re: Re: Re: Re: Re: slight knock in Oliver 1600 mo in reply to nobe, 01-26-2004 06:42:48
Is this a gas or diesel? Either way have you tried to short out the cylinders and see which one is causing the problem? How good are your manifold gaskets or is the manifold warped. Lots of things to check before you take the pan off.
nobe
01-26-2004 07:39:18
 Re: Re: Re: Re: Re: Re: slight knock in Oliver 160 in reply to ajax implement, 01-26-2004 07:00:56
Oops, that was a 7 foot bush hog.
Cutting grass, weeds, light brush.
nobe
01-26-2004 07:35:42
It's a gas engine. It's in good condition. Don't leak or use oil. No signs of coolant to oil leaks. Good power. New wiring, plugs, points. Will pull a 7 foot easy in 3rd. I usually use 2nd. I don't think it's a manifold leak. Engine hasn't been over heated. The noise sounds like metal to metal to me, but I know I need to keep an open mind to find the problem. How would I isolate each cylinder to check it out?
Thanks, Nobe
RAB
01-26-2004 08:12:05
 Re: Re: Re: Re: Re: Re: Re: slight knock in Oliver in reply to nobe, 01-26-2004 07:35:42
Short out appropriate plug lead and see if the knock changes. If it is a con-rod bearing it will probably go away while that piston is off load.
Regards, RAB
nobe
01-26-2004 08:19:25
 Re: Re: Re: Re: Re: Re: Re: Re: slight knock in Ol in reply to RAB, 01-26-2004 08:12:05
I will try that. I live in Southern Indiana and we've had freezing rain on top of sleet and snow. So I won't be doing much untill the weather clears up some. Thanks for the advice, Nobe
