60 gaskets bearings needed
Dave
01-25-2004 07:06:23
Does anybody know where I can get an engine gasket set, main bearings & sleeve o-rings for an Oliver RC 60 (Waukesha 160)?
Kenny Grimm
01-25-2004 08:57:00
 Re: 60 gaskets bearings needed in reply to Dave, 01-25-2004 07:06:23
Dave: I think I can get you what you need for your 60 engine. As far as engine bearings go, 66 rod bearings will work and 66 main bearings will work if you redrill the oil passages in the bearings. Also a 66 cam bearing will work as a replacement for the 60 as they are the same. Just finishing up overhauling a 60 for a guy now, and went through the engine completely. Would be glad to help with any questions you may have.
