Oliver 1950 GM
Tim
01-24-2004 12:51:55
I want to increase the horsepower in my 4-53 Detroit Desiel. It originally had N-50 injectors I replaced them with N-65. I have no more power than had before. I think I need to increase the air flow, bigger blower, adjustment? This engine has a Roots Blower NOT a TURBO. I need your thoughts. Thanks
Lee W
01-26-2004 08:47:19
 Re: Oliver 1950 GM in reply to Tim, 01-24-2004 12:51:55
I had the best results with N 55's, there isn't enough air there to use 65's. I have seen some guys use 60's with quite a bit of extra RPM, I used to turn mine around 3500, just guessing cause the tach didn't go that high. I had the 3000 rpm governor wts in mine. I have also used propane to help burn the fuel.
