Oliver 70 Serial#
Hayshaker5
01-24-2004 08:09:39
Would like to know where the SN Tag is located on an Oliver 70.
Thanks
ajax implement
01-24-2004 08:28:47
 Re: Oliver 70 Serial# in reply to Hayshaker5, 01-24-2004 08:09:39
Sitting on the seat looking ahead it is on the left side on the engine block. If it has a replacement block and no tag, you are out of luck, but there were many little changes made in the 70 models that these people can get you close if you provide some details. Good Luck.
Esev
01-25-2004 17:48:27
 Re: Re: Oliver 70 Serial# in reply to ajax implement, 01-24-2004 08:28:47
There is usually a casting date on the bottom of the belly pan. It will be torward the rear, near the joint with the transmission. There is also one on the bottom of the transmission too.
hayshaker5
01-26-2004 14:45:27
 Re: Re: Re: Oliver 70 Serial# in reply to Esev, 01-25-2004 17:48:27
Thanks for the info! I have a friend who is restoring an Oliver 70, and I sold him some parts off one we have had in the old gravel pit. He wasn't sure where the SN was located. Again thanks for the responses.
