can you put a gm diesel in a super 99 that wasnt a
Dave
01-23-2004 06:24:04
Is it possible to put a gm diesel in a super 99 that wasnt a gm tractor from the factory? i know of a super 99 that is in excellent shape but the engine is toast.I would love to put a 3-71 or better a 4-71 in it but never have done this. has anyone ever done this and what kind of work would this entail? thanx for any info. Dave
TLC
01-23-2004 19:13:02
 Re: can you put a gm diesel in a super 99 that was in reply to Dave, 01-23-2004 06:24:04
Dave
If the 99 has the original gas six cylinder it is a 302 cubic inch motor. The correct way to install a 3-71 in it would be to change the front frame. The front motor mounts are the same but the back ones are way off. I happen to have a front frame for a 3-71 if you are interested let me know.
David
01-23-2004 20:19:12
 Re: Re: can you put a gm diesel in a super 99 that in reply to TLC, 01-23-2004 19:13:02
tlc. i am interested. please e-mail me at [email protected]. thanx Dave
Bob
01-23-2004 16:42:37
I thought all Oliver Super 99s had Detroit 3-71 engines. What other engine did they come with?
ajax implement
01-24-2004 06:09:19
 Re: Re: can you put a gm diesel in a super 99 that in reply to Bob, 01-23-2004 16:42:37
A Super 99 will either hava 302 cubic inch Oliver/ Waukesha gas or diesel similar to a 320 in a Massey 1100 gas The Oliver has dry sleeves the 320 cubic inch Massey has no sleeves. Then the third choice was the 3-71 Detroit which is about 10 horse power better than the Oliver engines.
Mike
02-05-2004 13:22:14
 Re: Re: Re: can you put a gm diesel in a super 99 in reply to ajax implement, 01-24-2004 06:09:19
If you can the right 3-71 it'll fit right in.I took one out of an ac hd6 dozer.I'm working on putting a 4-71 in a 950 now.
Larry W.
01-23-2004 16:22:09
Dave email me, I can give you some suggestions on swapping motors that might help you.
Larry W.
01-23-2004 16:17:45
Dave, do you still have your original motor thats toast? Was it gas or diesel? How bad was it? Would you email me, I need some parts, maybe your motor would fit the bill. thanks.
Larry from MD
01-23-2004 09:39:56
Yes it can be done,but it can need lots of work.We did one 15 years ago.This friend bought an industrial engine,it had the blower on the wrong side.So he used a cutoff type saw to cut room for the engine to fit down in to the frame.He had to modify the engine mounts too and change where the oil cooler was mounted on the engine.The pto spline in the flywheel was a problem too.They did not weld braces around the cut out parts of the frame.It was still running the last time i saw it.Evan if you have the right engine you will have to cut the frame some to get it in.
David
01-23-2004 12:39:49
 Re: Re: can you put a gm diesel in a super 99 that in reply to Larry from MD, 01-23-2004 09:39:56
Larry, what engine did you put in?4-71? 3-71? i wouldnt try to put in the pto but i was wondering how bad it is to get the power to the tranny for i dont know what these use. coupler or chain or ?are they all the same on the super 99? i would like to go with a 4-71 . i wonder how hard it would be to find those dual air cleaners? thanx for all the info.
Larry from MD
01-23-2004 15:10:09
 Re: Re: Re: can you put a gm diesel in a super 99 in reply to David, 01-23-2004 12:39:49
They where all 371 conversions in the S99's.I do have a 471 in a moline GTA.There is a colapseable shaft between the engine and trans, similar to the S88.If useing the tractor for pulling you could avoid 2 of the problems the pto and the oil cooler.A 471 would be a hardfit as you would have to move the radiator forward and use it with no sheetmetal.I did see a 88 that was done that way when a larger herk engine was added.That tractor is still being used on a farm.
Dave
01-23-2004 16:33:05
 Re: Re: Re: Re: can you put a gm diesel in a super in reply to Larry from MD, 01-23-2004 15:10:09
I WOULD LIKE TO KEEP ALL THE SHEET METAL AND YES I WOULD USE IT TO PULL.WOULD THE COLAPSEABLE SHAFT WORK FROM THE 99?IM NOT SURE WHAT ENGINE IS IN IT NOW I WOULD BE GUESSING BUT I THINK I CAN GET IT REASONABLE AND I PROBABLY WOULDNT WANT THE ENGINE THATS IN IT.AT THE TIME I DIDNT PAY MUCH ATTENTION BECAUSE IT WASNT A GM MODEL AND THEN I GOTR TO THINKING!!! YOU KNOW HOW IT GOES.... DAVE
