990 steering
GHH
01-22-2004 07:28:57
There seems to be to much play in the steering on my 990. Is there a way to eliminate this without disassembling the whole steering sector? Thanks for any help.
Lee W
01-22-2004 14:55:34
 Re: 990 steering in reply to GHH, 01-22-2004 07:28:57
There are two adjustments on the gear box, one is on the bottom the other on the side of the gear box. I have seen several with the top bearing bad in the gear box, when it gets real bad the steering shaft trys to screw itself out of the gear box when you try to turn to the left. The only place I have found the bearing is from Agco.
