880 hydraulic question/ 1755 for sale needs motor
Luther
01-21-2004 16:44:39
How is everybody? I hope o.k. Went to use the left side of my remotes to find out they're not working. It seems to work on the down stroke (it pulls the motor down), but nothing on the upward stroke. The right side works fine but is hooked to my three point. Any help is greatly appreciated. The 1755 is down around Springfield, MO. It has a cracked crank plus a vent hole in the block which has been welded at some time. The guy says he was grinding feed when it started knocking. It has dual remotes and a three speed, 38 inch tires (fair), and wide front . He also says the sheet metal is straight. All for 1500. What do you think? Thanks again.
Brad
01-21-2004 21:55:41
 Re: 880 hydraulic question/ 1755 for sale needs mo in reply to Luther, 01-21-2004 16:44:39
There is a good possibility that your hyd baseplate has a crack in it for that outlet. of course o-rings or a valve problem would also cause the same symptoms.
E J
01-21-2004 19:56:16
I picked one last year with broken crank but no inspection holes gave 1200 wasn't to bad a tractor.310 cranks are fairly exspensive for a good one 600 to 800 last time I checked maybe you have heard diferent.I have seen quite a few welded up blocks if they don't take the cam out or the injection pump.Have a 880 too but I cant find my operators manual to help you out.
old
01-21-2004 19:25:05
I don't know what you might be looking for but I know a guy in russelville that has a few olivers forsale, or dod the last time I talked to him. Drop me an e-mail and I can give you his phone number if you want it. He has a couple I want but my back pocket says no
dean
01-25-2004 05:09:05
 Re: Re: 880 hydraulic question/ 1755 for sale need in reply to old, 01-21-2004 19:25:05
russellville?..ark?..mo?..do you have a name or number?..thanks
old
01-25-2004 09:04:14
 Re: Re: Re: 880 hydraulic question/ 1755 for sale in reply to dean, 01-25-2004 05:09:05
Missouri
s feldman
01-22-2004 07:58:52
I am also looking for fwd olivers, any in russelville, or any place else, reasonable or in need of repair?
mapleman
01-21-2004 19:21:07
sounds like a good candidate for a cummins to me...
1500 sounds okay - depending on hours and actual condition of the tractor...
good luck.
Luther
01-23-2004 18:13:29
 Re: Re: 880 hydraulic question/ 1755 for sale need in reply to mapleman, 01-21-2004 19:21:07
Brad, you say my base plate might be cracked, is that why oil is seeping out below the hydraulic exits on that side? I tightened the mounting bolts of the unit it seemed to help stop the seeping. It had'nt done this before I started using these outlets. As far as the 1755, I was reminded of house plans after I wrote that post, I tried! Thanks again!
