snow removal
Bruce
01-21-2004 10:33:23
Looking for advice on snow removal. I have a 1961 540 and I am wondering what you would recommend for the best method of snow removal. I have the loader with a manure bucket. I have seen some sort of blade which is carried behind, What is this called and does it work? I live in an area that often gets large snow falls. Can I operate a small blower? What method is the "easiest" on the tractor?
Kelly MT
01-23-2004 20:02:40
 Re: snow removal in reply to Bruce, 01-21-2004 10:33:23
We get a bit of snow here, a mixture of powder one time and wet heavy crap the next. If you get mostly powder I like a blower. I have a 7' three point that really moves some snow on my Versatile 150. It will plug in wet heavy snow. That's when my 1850 Oliver FWD with a JD 260loader and 8' bucket shines. Your bucket or plow blade needs to be as wide as your tires. A back blade makes you drive on and packs the snow ahead of the blade. You can turn the blade 180 and back up to push the snow and this works well for small areas but to clean out a long road it's a pain. The other thing is chains. If you do a lot of plowing get a good set of chains. Have fun, PK.
old
01-21-2004 14:19:20
If you can find or make one a front plow works best for plowing snow that way your drive tires are running on little or no snow. I made a V plow that hooks to my loader its 9ft wide and 2 foot tall and I can really move snow with it and up in a higher gear to boot. I won't tell you what its on since it isn't an oliver, my oliver gets to sleep in the winter.
