Perkins
paljoey
01-20-2004 17:11:52
I have a perkins 4 cylinder diesel engine that I would like to rebuild. The model# and serial# has worn off. IT is out of a cockshutt tractor that I have no idea what the model # was. The tag that I did find said it was a perkins four/ 207/D. If anyone has any idea what tractor and motor this would be let me know. Thanks
Toocold
01-24-2004 07:05:26
 Re: Perkins in reply to paljoey, 01-20-2004 17:11:52
Been trying to e-mail you. permanent fatal errors, twice. Have a price on the head and gasket.
Please advise
paljoey
01-24-2004 07:37:25
 Re: Re: Perkins in reply to Toocold, 01-24-2004 07:05:26
Too cold my email is [email protected] Give it a try. and thanks
Toocold
01-22-2004 17:06:20
I have a completely rebuilt head for that engine.Priced reasonably. Rebuilt by a professional engine technician. Comes with a new gasket too.
paljoey
01-22-2004 17:53:10
 Re: Re: Perkins in reply to Toocold, 01-22-2004 17:06:20
Toocold could you email me a price on the head please.
P Heisey-harleysville,PA
01-21-2004 15:30:35
Hi Paljoey,
I have the parts you need for your Cockshutt 560 with 4-270 Perkins diesel engine. Valves, head gasket, bearings and much more!
Please email or fax your list for my quote.
Phil Heisey 215-256-8651 FAX 215-256-1203
paljoey
01-21-2004 14:26:27
I did find some #'s on the block. C0280103 is at the top. Under that is DA17411. There are some #'s on the covers that are on the side of the block 0240752. The head has a # on it as well 0290037J. Any help identifing this engine would be great. Parts that I am looking for are parts to rebuild head. Head gasket. Rings and main bearings..
thanks paljoey
hans kreisel
12-13-2005 12:54:28
 Re: Re: Perkins in reply to paljoey, 01-21-2004 14:26:27
My brother has a similar engine. it was built in a boat. he needs parts for rebuidig it. does anyone have an addres?? he mostly needs an overhaul kit for the waterpump. I traced the engine by the number DA17411 and came out here. Is it defenitely a Perkins 4.270
Please forgive my writing, I'm Dutch.
j. Schwiebert
01-21-2004 15:32:29
Go to www.hartparroliver.org and send me a U2U and since Irv said I am a nice guy and like my diesels I will try to help you. What are spark plugs?
Irv
01-20-2004 17:57:55
You probably have the Perkins 4-270 which was used in the Cockshutt 560. It was the replacement for the Perkins L-4 that was used in the Golden Eagle and first year of the 560. It was a bit better motor. They are hard to find parts and very expensive to rebuild. I may have some odds and ends for this motor and so would Phil Heisly let us know what you may need and we might be able to help. If you need other info on this motor let me know also post for John Schweibert as he has alot of info too!
klf
01-20-2004 17:17:52
The serial number should be stamped into the block. Look on the engine again.
Russ
01-21-2004 16:50:57
 Re: Re: Perkins in reply to klf, 01-20-2004 17:17:52
WHAT IS IT? MAYBE A 1959, 560STD, PERKINS 4-269CID DIESEL, XMSN 6F-2R, 50 HP(PTO)
AND 6150 LBS. SOUNDS LIKE THE OTHER STRINGS
ON THIS ISSUE CAN SET YOU UP WITH MOST OF
THE PARTS YOU WILL NEED IN THE REBUILD.
HAS TO BE A LOT OF THESE ENGINES IN CANADA
AND ENGLAND.
