88 update
ChadS
01-19-2004 20:17:57
Well I got the 88 torn down. I am getting ready to pull the engine out of the frame. I was wondering about how the coupler shaft comes apart on the drive shaft. It looks like a slip coupler. Should i leave it intact and pull the shaft out of the clutch, or disassemble it? I found a good set of pistons 4-1/8 bore flat tops to install when I finally get #4 to come out!! HA HA!! I was surprized that all of the bolts came out with no problems. I need a good intake/exhaust manifold for 88 gas. Chad
steve
01-20-2004 11:55:51
 Re: 88 update in reply to ChadS, 01-19-2004 20:17:57
you have to pull the pto to get the engine out as it goes into the crankshaft to get live power.also i have a good manifold i would sell at a good price.email me your phone # and i will call you.i have a complete engine for parts
E J
01-20-2004 08:48:52
Take the two vertical bolts out and the pointed set screw then slide the coupler forward leave it on the clutch holow tube then pull engine.
Jerry B
01-20-2004 05:45:02
Chad,
Slide the pto out about 18 inches or more. Remove the bolt in the side of the coupler and collapse the clutch shaft and coupler into each other. This will allow the clutch shaft to be removed as the engine moves forward. This makes life much easier.
Jeff
01-19-2004 20:45:12
Chad, it will probably beeaiser if you haven't already done so to pull the PTO unit from the back . That shaft runs through the splined drive coupler and into the crank I think. However if your only going to pull the motor I would probably just leave the splined coupling hooked up. Don't quote me on that as I have only been inot the clutch and stuff on one once and it was a few years ago.We took the PTO out and unhooked the splined shaft also.
