Cockshutt 35 PTO?!?!
Red
01-18-2004 09:51:21
Will"Live-PTO"from Cockshutt30 fit a Cockshutt35?
P Heisey-Harleysville,PA
01-18-2004 13:17:23
 Re: Cockshutt 35 PTO?!?! in reply to Red, 01-18-2004 09:51:21
Red,
The PTO housing is different between the 30 and 35. Some parts of the clutch pack inside are the same. The design is very similar, but the 35 is heavier duty. They will NOT interchange. The 35 case and clutch pack are the SAME as on the Cockshutt 40 and 50. Phil Heisey 215-256-8651 eve. FAX 215-256-1203
ajax implement
01-18-2004 10:08:05
If you mean the complete PTO, the answer is NO. A 35 is more like a Cockshutt 40 than a 30. The 30 final drive is a Timken built unit The 35 is a Cockshutt built and designed unit.
