Oliver 77 Manifold Gaskets
John in IN
01-18-2004 08:56:49
I went to the local AGCO Dealer and checked on a set of manifold gaskets. $5.05 a piece which it takes nine so that comes to $45.45 (seems higher than most brands I have restored.). I had the manifold surfaced ground at the local NAPA store and they couldn't get gaskets there. The AGCO dealer carries AC manifold manifold gaskets which are similar (4 cylinder though) that are only $14 a set.( 6 in a set). Are there any aftermarket sources or can I buy two sets for a WD45 for $28 if they will work. Thanks.
Wes Dorhout
01-18-2004 16:00:02
 Re: Oliver 77 Manifold Gaskets in reply to John in IN, 01-18-2004 08:56:49
I carry this gasket set with a carb gasket included for 20.00 My # is 712-324-2760 There is a diference from 77 to 88.
John in IN
01-18-2004 15:36:08
 Re: Re: Oliver 77 Manifold Gaskets in reply to Chris, 01-18-2004 14:52:43
Thanks, I just shot them an e-mail. I can't believe the dealers price on those gaskets. Thanks.
J.Schwiebert
01-18-2004 09:52:47
You did not say gas but since you asked for 9 I would guess it is for a gas. The diesel is a different size. Victor makes the gasket, I know you can get the 88 gaskets there NAPA and I know Ricks Agriparts has them and I have a jar full of them too
John in IN
01-18-2004 13:57:26
 Re: Re: Oliver 77 Manifold Gaskets in reply to J.Schwiebert, 01-18-2004 09:52:47
Sorry about that, it is a gas. Is there any difference between a 77 and an 88 manifold gasket?
