428 cockshutt combine
spuds
01-17-2004 20:47:08
Can anyone tell me what brand of engine was in these, and also what size was it? THANKS!!!!
Andrew
01-18-2004 12:15:09
 Re: 428 cockshutt combine in reply to spuds, 01-17-2004 20:47:08
If the 428 Had a 6.6 compression ratio, isnt that kind of low, i know in the 542 they boosted the compression to 10.3 to 1 then every second year we blew a head gasket.. If you shaved the head on a 428 like 20 tho and bring the compression to 8 or 9 that would be a better engine and more power and you wouldent have the head gasket trouble plus the engien would be more snapy
J. Schwiebert
01-18-2004 08:41:37
The 251 cubic inch engine was also used in the 525 Oliver & Cockshutt machines as well as in the 2890 Moline which is the same as a green or red 525
P Heisey-Harleysville,PA
01-18-2004 04:56:32
Spuds,
The Cockshutt 428 SP combine uses a H.D.Chrysler 6 cylinder 250.6 cu. in. gas engine. 3 7/16 bore and 4.50 stroke. 6.6 compression ratio. If interested the Cockshutt 427 SP combine uses a 236.6 cu. in Chrysler engine.
Please let me know when I can assist you further.
Phil Heisey 215-256-8651 eve. FAX 215-256-1203
ajax implement
01-18-2004 03:52:15
Chrysler Industrial. I am not sure of the displacement and no doubt the engine was built in Canada which makes it different than the American built engine. The very last 535 models had an American engine.
