White 2-180, clutch
Tremayne Hadenf
01-16-2004 15:15:32
The first time I used the tractor, the cluth seemed to be disengaging right at the bottom of the pedal travel. A couple of hours later the clutch would not disengage. Any ideas? My only thought is the throw out bearing went through the fingers. All the linkage seems to work. I just parked it and have not began to work on it.
my first experiece with white tractors.
it has the 3208, with over under tranny.
thanks
tremayne
Lee W
01-16-2004 15:31:57
 Re: White 2-180, clutch in reply to Tremayne Hadenfelt, 01-16-2004 15:15:32
The most common problem I have found is the center plate of the clutch is broke, it is a dual plate assembley. The early ones used a 6" center hub the later one's used a 7". We tore down one that had a 6 and a 7, the 6" hub was broke and the 7 was not. You could be right too on the fingers.
Tremayne Hadenfelt
01-16-2004 15:46:36
 Re: Re: White 2-180, clutch in reply to Lee W, 01-16-2004 15:31:57
thanks Lee, any info or ideas are appreciated because this is my first time with a White tractor and i am not that familiar with them. all the rest of my "white" tractors have old abe, the civil war eagle on them!!! (JI Case)
tremayne
