need info on carb
kevin
01-15-2004 15:47:22
i have a oliver 1550 that needs the carb rebuilt. anybody know who made the carb and what model? the engine is a 6cylinder wakershas thak you kevin
IanC
01-15-2004 17:45:37
 Re: need info on carb in reply to kevin, 01-15-2004 15:47:22
The ID for Marvel/Schebler carbs is usually a brass tag attached to the lower body of the carburetor opposite the choke lever. If the tag is missing, take the carb apart, and take the pieces with you to a dealer that's been around a while even if it's another color. Most maufactuers used Marvel carbs and they should be able to match the orifice in the needle valve, float, gasket etc.. Going by the book is ok IF your sure of the history of the machine, but there has been plenty of years, (and maybe hands) on that machine since it left Charles City.
old
01-15-2004 16:39:49
The info I have says its a TSX903
kevin
01-15-2004 18:50:32
 Re: Re: need info on carb in reply to old, 01-15-2004 16:39:49
thanks for the info,will match it to my tractor and then i should be in good shape later
