Hydralectric Cylinder Brackets- Need info
Dan
01-13-2004 14:50:17
Does anybody have a close-up picture of their Hydralectric brackets? My 66 is missing the bolt and wing nut I gusess that bolts the 2 halves together. It also doesnt seem to hold the cylinder right because it has 1/4" thick flat pieces welded to the inside of the curved portion of the clamp. It's hard to tell if the pieces were added or original. Maybe I have the wrong cylinders, or have them mounted wrong? The cylinders have a casting # of 1K2202A. I think they are 3" in dia.
Thanks in advance.
J. Schwiebert
01-13-2004 15:19:14
 Re: Hydralectric Cylinder Brackets- Need info in reply to Dan, 01-13-2004 14:50:17
66 cylinders if they are the correct cylinders are 2-1/2 inch to compensate for the smaller GPM pump.
