880 Shift pattern
JT
01-10-2004 12:49:19
Can someone please tell me, or tell me where I can find the shift pattern for my 880, I just need to know where there at, All I know for sure are reverses. Thanks for the help
DuaneWKKC
01-12-2004 09:23:00
 Re: 880 Shift pattern in reply to JT, 01-10-2004 12:49:19
R2...6
...|.-.| .3....4
....N
R1...5
..1...2
remove the dots to see correctly! whouldnt hold spacing correctly without them.
I believe this is right, been a long time since drove my old 880D, like 15yrs. Hope to get another one someday....
DuaneW.
J. Schwiebert
01-10-2004 12:54:01
O. K. Where are the reverse gears. If you have a spur gear transmission the gears will be different than on the later helical geared transmissions. Look at the last three numbers of the serial number. 873 is the most common helical transmission At least send us the serial number.
JT
01-10-2004 16:31:34
 Re: Re: 880 Shift pattern in reply to J. Schwiebert, 01-10-2004 12:54:01
The reverse is to the left and up. I will get the serial number tomarrow, but I know that it is a 58' model , serial # is something in the 69000'S
J.
01-11-2004 16:35:04
 Re: Re: Re: 880 Shift pattern in reply to JT, 01-10-2004 16:31:34
Remember you have a double H pattern with a reverse in each range. The high ranges will be in the upper H. 3rd will be below reverse. 6th will be up and across from reverse. Fourth will be under sixth. In the lower neutral first will be down from reverse. On the right side you will have fifth in the up position and second on the bottom.
