880 Head
Bill
01-09-2004 16:05:31
Little history. When I pull my 880 and lug it down to 1400 rpm it would miss.It run good wide open. So today I pulled the head to check the valves.Well No. 2-4 cylinders were white and I could see cracks from the valve to the injector maybe half inch long .What to do. I have it welded or get a rebuilt. It did not use water. Thanks for any advice. Bill
J. Schwiebert
01-09-2004 16:09:56
 Re: 880 Head in reply to Bill, 01-09-2004 16:05:31
I would worry if there were NO CRACKS!. There is no water where you are talking. Some of those old 88 heads had 8-10 cracks.
Luther
01-09-2004 17:13:41
 Re: Re: 880 Head in reply to J. Schwiebert, 01-09-2004 16:09:56
Just rebuilt an 880 with the same cracks. I had a guy reweld them and grind the valves. Seems to be working just fine if I could get injection pump straightened out! They're known for cracking. Good luck!
