Compression Test 880 Gas - what PSI to expect
kman
01-04-2004 11:23:37
What sort of numbers should be expected from a compression test on an 880 gas? I just checked mine and I'm getting 150-160psi on all but one cylinder. #3 cylinder showed about 125 at first but I checked this a number of times and it seemed to increase to 130, then 140 then finally 150. I checked with engine warm at first and wondered if readings on #3 went up as the motor cooled. Does this indicate a head gasket, ring or valve problem?
