Oliver 550 coolant temperature sensor is broken
John from Sagin
01-04-2004 11:04:15
My heat gage does not work. I have narrowed the problem down to be the temp.sensor/sender that mounts into the engine block. It is a 1969 550 White/Oliver gas.
The local NAPA dealer carries heat sensors but they all vary in output characteristics. Does anyone know the resistance value in ohms @ 220 degrees F. that is required to make the gage read properly???
