White 2-70 hydraulics
Tony Becker
05-23-1999 08:45:47
I have a White 2-70. The 3-pt works good when the oil is cool, but performance goes downhill when it get hot. I notice there is a separate oil cooler in front of the radiator; is this the original stock setup? The I&T manual only mentions separate coolers for the 2-150; for the 2-70 it says only to remove the cooler lines from the radiator. This cooler is somewhat plugged up from dust/oil accumulation; what's a good way to clean it out? Do I have to remove it, or should I try a pressure washer at low pressure? Is there something I can substitute for the "Type 55" fluid? The dealer around here closed up shop and I would have to take a ride to the next state for this oil; is the something special about it? Thanks for help.
Bill
05-25-1999 19:31:16
 Re: White 2-70 hydraulics in reply to Tony Becker, 05-23-1999 08:45:47
As far as the oil, we use Penzoil Hydra-Tranz in a lot of Olivers we have worked on and it works well. My dad has an implement dealership and we have used it for over 20 years in everything from an 88 to 2-105.
As far as the hydraulic cooler, air or a nozzle on an water hose may be the best bet so you don't damage the fins on the cooler.
Hope this helps.
Chris
05-23-1999 15:19:50
The oil cooler is stock equipment. It cools the oil that goes thru the steering circuit. It can be cleaned with air pressure or a power washer.(one that isn't going to blow the fins out of it.)
If the 3 point cycles up and down alot, chances are you need new o-rings on the 3 point lift piston. If the 3 point stays where it is supposed to after the oil is warm then the hydraulic pump is probably getting worn. Once the oil is warm, the 3 point may not even move when the engine is idling because the priority vavle will divert all oil flow to the steering to keep it working. The best thing to do is to get someone to check it with a flow meter thru the remotes. This tractor is pretty much a 1655 with different colors. Hope this helps.
Bill
05-23-1999 18:49:27
 Re: Re: White 2-70 hydraulics in reply to Chris, 05-23-1999 15:19:50
Good advice. I'd just like to say that you can't
over-emphasize the fact that the cooler fins
need to be kept clean. I'm in the habit of weekly
cleaning of air filters and rad fins under normal
use and daily when I'm spraying. I've really
noticed a difference in temperature since I've
started doing this.
