88 vs. S88
not sure
01-03-2004 13:04:29
wondering what I have. serial # says 1956, has super frame, 1 axle is 2.75, other is 2.83 aproxx. desial head is a 190A Just wondering
A.P.
01-03-2004 14:18:56
 Re: 88 vs. S88 in reply to not sure, 01-03-2004 13:04:29
A couple more things to check, the casting date on the bottom of the transmission/rear end housing. Are the brakes the disk or band type?
Good luck,
A.P.
J. Schwiebert
01-03-2004 14:42:07
 Re: Re: 88 vs. S88 in reply to A.P., 01-03-2004 14:18:56
Don't forget Fleetline 88's have disk brakes from the fall of 52 to the end of their production. I forgot to ask, is this a gas or diesel? Fleetline 88 diesels only came with one fuel filter. I know there was a kit to put the same filtering set up as a Super had with the 2 filters, but how many have you seen that were converted?
J. Schwiebert
01-03-2004 13:29:14
The Super 88 was introduced in the fall of 1954,
What is the casting number on the block? It is located behind the starter. It would be 1K-100? and then a letter. The 190 number is the Waukesha casting number
