Pulling an engine on an oliver 77
Ryan
01-01-2004 16:27:16
i am trying to pull an engine on a 1951 oliver 77. i have taken all of the engine mount bolts out and took the drive shaft coupler off also, but i still can't get the engine out. so if anyone could give me some help on how to get it out i would appreciate it. thanks Ryan
ajax implement
01-01-2004 16:55:22
 Re: Pulling an engine on an oliver 77 in reply to Ryan, 01-01-2004 16:27:16
Did you pull the long power take off shaft. It is splined right to a hub in the flywheel?
Ryan
01-01-2004 18:59:04
 Re: Re: Pulling an engine on an oliver 77 in reply to ajax implement, 01-01-2004 16:55:22
How and where do u pull the pto shaft out of the flywheeel. Thanks
VADAVE
01-02-2004 05:42:07
 Re: Re: Re: Pulling an engine on an oliver 77 in reply to Ryan, 01-01-2004 18:59:04
If you have been pulling on the engine with this shafty still in the tractor I suggest you take it all the way out and checkmto make sure it is still straight. If not it can be straightened. This happened to me the first time I had a tractor worked on. Fellow I had work on the 1855 apparently hadn't worked on Olivers before and tried to pull the engine with the PTO drive shaft still in the tractor. Put it back in bent. Made the clutch drag. Pulled the shaft, rolled it across the floor and bent the shaft back with a press. I was lucky.
WFE
01-01-2004 20:09:20
Ryan, the pto shaft, as you see it on the back of the tractor, remains in place. There is a long drive shaft, however, that is splined into the engine flywheel that runs all the way through the transmission/rear end that must be slid out so that it is completely disengaged from the engine flywheel; it must in fact be pulled out as far as the transmission input shaft, where the coupler you slid back is. At the rear of the tractor, you'll see the cover for the dry pto clutch retained by 4 capscrews on the bottom side of this cover. Remove them, then engage the pto lever on the tractor to remove the cover. Behind the pto clutch assembly you'll see 3 capscrews; remove them and then pull on the pto clutch assembly. It may be seized where it is splined into the flywheel hub, but it will come out and can either be removed completely or just slide it out and leave it hang out the back of the tractor about 5 feet. You can then remove the engine. Good luck...
Jeff
01-01-2004 19:30:59
take it ou from the ack of the tractor. take the bolts out that hold the PTO in the rear and slide it out
Jim Creamer
01-01-2004 16:54:10
Have you pulled the PTO shaft yet?
