Super 55 hydraulic problem
Dennis
05-22-1999 08:12:41
The hydraulics on the three point will not lift unless I put depth control lever down and then back up before lifting three point with the normal control. I must do this each time I need to lift it up. What's wrong here?
Paul Stanley
05-22-1999 11:28:06
 Re: Super 55 hydraulic problem in reply to Dennis, 05-22-1999 08:12:41
Does it do it all the time, or just after you have run it for a while? If it does it after you are running for a while, it may be that you are getting foaming action in the hydraulic oil. This has to do with the return being to high in the resevoir and foaming on the surface. Oliver had a retro kit that consisted of a tube returning the oil below the surface. If it is happening all the time it may be you need to adjust the external and internal draft control linkage. If you need more information email me. I have the shop manual.....
