tractor spec
h.willis
12-30-2003 21:21:21
i have a super 55, sr #40190-518 & spec # 150113
i would like to know what engine & other things
is original on this tractor. thanks in advance
ajax implement
12-31-2003 05:31:07
 Re: tractor spec in reply to h.willis, 12-30-2003 21:21:21
Your tractor is a late 1956 model. Engine is an Oliver/Waukesha 144 cubic inch. 3.500 bore by 3.750 stroke. 518 (last three numbers of serial number) indicates it has the standard transmission & final drive which is 6 speeds forward and 2 reverse speeds. it has a gas engine but the other 4 numbers of the spec number also indicate tire size, 3-point, etc. I do not think I ever had a sheet to decode those.
