Super 88 Electro Hydraulic
mark
12-30-2003 18:44:58
I have a super 88 and was wandering how to tell if the electro hyd. was working. I also recentlt bought an old oliver hyd. cylinder at an auction, but it doesn't have the electric plug on it anymore, are these available anywhere.
Thanks, mark
Joe
01-01-2004 04:23:58
 Re: Super 88 Electro Hydraulic in reply to mark, 12-30-2003 18:44:58
If your cylinder has a steel barrel, you might want to pull it apart to be sure the barrel is not pitted on the inside. Some hyd repair shops can cut off a barrel and weld on a new one but it is a little pricey - same with a rusty rod.
Korves Bros has cable and plugs that will work, but the last time I checked it was not the molded style that your Super 88 with the Version III system would have.
ajax implement
12-31-2003 05:39:12
The hydra lectric was designed to work with an Oliver cylinder. Two switches are used to hold (detent) the handle while it is in the raise or lower position. When the circuit is broken, the handle being spring loaded gos back to the neutral position. An electomagnet is also incorporated in the cylinder which allows you to change the stop (depth of implement) from the seat. You did not say what type of cylinder you purchased. If it is a cast cylinder, it was used with the start of the 18 & 1900 tractors in 1960 and uses a 3 wire cable instead of the four wire cable used with your Super. If you have a test ligh you can check the condition of the internal switches. The green wire marked G on the tractor cable is the ground. the red (R) one sets the depth and you have to move the lever to the side. The black and white wires are for down and up. Hope this helps and answers what you ask.
