Super55 PTO (again sorry)
Stu
12-28-2003 17:27:58
I have rebuilt my Super 55 PTO clutch, new seals/plates and discs. All new, cleaned, and shiny. Its all together now and running. With no load, the spins fine. With a light load, it slips. I have it re-tightened as much as it possible can from the underside, but it still slips under load. I wonder what I am doing wrong?
Its been done all by the book, step by step. And no leaks now either.
Any help appreciated, I want to be able to rototill in the spring.
Pete
12-28-2003 18:37:01
 Re: Super55 PTO (again sorry) in reply to Stu, 12-28-2003 17:27:58
Did you adjust the tightness untill you had apply 32# of pull 2' above the pivot point to snap the PTO clutch in? If you adjusted it so, did you replace any parts? Why I ask is that the S55 std pto takes 5 driven and 4 drivers where as the later 550 pto takes 6 driven and 5 drivers, and if you used any of 550 PTO parts then you might not be able to get it tightened up enough to spin a load. Just a thought.
Make sure that you have it adjusted as above, must be 32#!!!
Pete
