Oliver 88 fuel tanks
Matt
12-26-2003 20:35:32
Will an 88 "gas" tank interchange with an 88 "diesel" tank? Part number for gas tank is K-822-A. Part number for diesel tank is K-822-B. Parts book says change in suffix following part number affects interchangeability. Have not always found this to be the case. Does anyone know for sure?
J. Schwiebert
12-27-2003 08:12:36
 Re: Oliver 88 fuel tanks in reply to Matt, 12-26-2003 20:35:32
The 88 diesel tank has provisions for a fuel return line and a seperate water trap to drain condensate. So a gas tank will not work on a diesel but a diesel tank would work on a gas if you put pipe plugs in the two holes. Confused? Ask away
