77 Sleeve dimensions
Ryan
12-25-2003 14:04:07
i need to know what the sleeve dimensions on a 77 oliver are. i need to know the ID, OD and the length and any other dimensions anyone else might have.
Thanks
Ryan
dan
12-25-2003 19:39:55
 Re: 77 Sleeve dimensions in reply to Ryan, 12-25-2003 14:04:07
flange od is 4.309,pilot is 4.092, lower seal area is 4.028, length is 7.062.
Ryan
12-25-2003 20:21:22
 Re: Re: 77 Sleeve dimensions in reply to dan, 12-25-2003 19:39:55
Do u happen to knwo what the bore of a 77 sleeve ia
Thanks
ajax implement
12-26-2003 02:52:00
 Re: Re: Re: 77 Sleeve dimensions in reply to Ryan, 12-25-2003 20:21:22
A fleetline 77 has a 3-5/16 inch bore (3.313)A super 77 is. 3-1/2 (3.500) These sleeves will fit in a 77. If you have a 3-9/16 bore they are M & W. If you have a 3-7/16 bore sleeve and a smaller wrist pin (less than one inch) they are from a 185 Waukesha Military engine. If you have a 3-5/8 bore (3.625) they are from a 550/1550. All these can be found (will fit) in a 77 engine
